Just to clear up that earlier misnomer. It wasn't Duckboard
, it was Dukkaboard. Evidently this is pretty similar to Marmox. Anyway, as ever, a question or three:
1. The wall to be tiled is 1,850mm x 650mm. The Dukkaboard panels are 1300mm x 600mm. The total surface area of the wall is, then, 1,2sq m. The total surface area of the 2 panels is 1,6 sq m. So, with just two panels, I have enough panelling to cover the entire wall, but only if I resort to cutting them into several irregular pieces. Is it acceptable to do this or should I look to obtain a third panel so that I have three regular(ish) pieces – 3 times 650 x 600? In fact this would still leave an area of 50mm x 650mm uncovered but I an extra piece that will cover this part.
2. A Dukkaboard info sheet describes using stainless steel fixing dowels for solid walls, whereas I was intending to use screws and washers as shown earlier. Do you tyhink this is OK?
3. What is the best tape to use for the panel joints?
Cheers.
Cheers.
