Agree with that, your better off just using water but don’t overdo it if the bricks are low absorbtion or you’ll have problems getting the render to stay on there; build it out in stages as recommended previously.no dont pva the wall just damp it down,
Sorry steve but it then starts to go a bit wrong;
Definitely not advisable in this case due to the weight of tiles (32 kg/sqm + addy) ; Gypsum skim will only take 20 kg/sqm & it must be primed when using a cement based addy or it’ll react with the Gypsum. I think the OP may still have trouble with the render bonding where it’s only 5mm thick.but if i was you i would give the wall a skim first
PVA is brilliant for plastering but never use it over a tile base, particularly with heavy tiles in a wet area such as this. PVA remains water soluble & the water in the tile adhesive causes it to re-emulsify reducing initial adhesive “grab” & give tile bonding problems; used in a wet area it could result in your tiles falling off the wall.followed by a coat of pva before you tile it
