Hi
I'm a novice at carpentry. Trying to fit some floating shelves in an alcove. I'm using these concealed shelf supports:
http://www.sdslondon.co.uk/concealed-shelf-supports/concealed-shelf-support.html
For the shelves I'm using 25mm window board, it's about 210mm deep. As you can see from the link, I need to create a rectangular notch on the back edge of the board to conceal the rear plate of the support - it needs to be 72mm wide x 22m high x 12mm deep.
I've been using a chisel to create this notch but I'm finding it quite difficult and time consuming - I need to do 9 of these shelves and 2 notches in each shelf. I was wondering whether it would be possible to do this job with a router?
I've never used a router before so I thought I would ask before going out and buying one. Also, if anyone has any better ideas on how to do it, I'm all ears. Or any suggestions for a different type of wood to use.
Thanks.
Thanks.
