Hi Guys
Just in the process of fitting a filler overflow to a new bath and a fixed shower head above it both supplied from a diverter valve.
The Valve has hot and cold feed inlets in 1/2" and two outlets, one in 3/4" which is to be used for the bath, the remaining 1/2" for the shower head.
Question is ...
For the best flow and pressure should i run the pipework from the 1/2" connection on the diverter valve to the shower head in 15mm or 22mm.
The system is gravity fed and the run of pipe from the valve to the shower head will be around a 6m long as valve will be at opposite end of bath to the shower.
cheers for any advice
Keith
Question is ...
Keith
