can possibly get 1 2moro for you. There is a hole for the cable to enter the fitting, this is right in the centre of the top. All other holes are small ones that are predrilled for self tappers and im assuming they are for other models of fitting maybe to hold either EM fittings or larger ballast etc.
yes fittings designed soley for suspension are likely to be different, but they tend to be fancier ones in aluminium rather than bog standard steel ones..
