Relocating where the electric cooker will be located for a new fitted kitchen. Not decided which oven to fit yet or exactly where in the kitchen it will be located, cable length is likely to be between 3m and 12m from the CU laid behind a few inches of insulation (basement kitchen at the back of the property, very cold so bringing the walls of the room in a few inches so it's better insulated).
Plan is to fit the cable and when the ovens fitted have an electrician connect it to the CU.
If I've understood the 'average' oven I'd fit 6mm cable, but some double ovens would need a 10mm cable if the cables at the 10+m range in insulation.
If I use 10mm cable and go with a single oven are there any possible issues with that? Basically is it OK to use 10mm cable when you only need 6mm?
David
David
