strange fishy smell
6 Aug 2010
Help!! My family and I moved into a brand new house 6 years ago. Within a couple of years we started noticing a slight strange fishy smell in the hallway. Never have been able to locate it. It usually goes away in the winter and comes back in the summer. This year it is terrible!! you can smell it all over the house. We have no idea where it is coming from.
Was it a reposession house? Its not unknown in the UK for people being evicted to leave nasty surprises for the next occupant, or to do a bit of slash and burn with the electrics and plumbing.
too.................. many............................. jokes........................!!!! :wink:
anyway, got air con?
really in the USA?
fishy smell = hot / burning paxolin type plastics ( used for electrical insulation, back of sockets etc.. )
It wasn't a repo. It was actually a new construction. We are the first owners and we have kept it up very well. By the way, the hotter it gets outside the worse it is.
some paints give off a smell, some floor coverings give off a smell..
do you have air con? / central air etc?
really in the USA?
fwiw im with you on this cj
the standard of construction over here leaves a lot to be desired
they would be strung up in england :evil:
Lot of great suggestions but where do I begin? Do I need to contact my builder of call someone in to check it out?
She made the same post about a year or two ago.
She has been in the house 6 years so possibly still needs an answer.
That said I have seen a few posts on this or very similar subject but not by this person who only joined the forum recently...
Anywhere near the gulf coast?
If so, apply to obama's 'BP clean up/rip off' fund...
not much proof of contamination needed... :wink:
Thank goodness we are not near the coast. I did see some info on the other person's post that suggested electrical issues. I just joined today. I My dad is a master electricion. I think I will get him out here for an inspection.
a strange fishy smell is most often caused by an overheating electrical accessory, such as a socket, switch or junction box
apart from electrical faults, it can also happen if you have a high-wattage lamp in a lampholder that is designed for lower power, or where a lamp is enclosed e.g. in a dowlighter and the heat can't get away/
if you turn off the power for a few hours and the smell goes away, you have a clue. if the smell occurs in winter it may be to do with a heater; if in the summer it might be with a fan or air con; if at night it may be lighting; if when cooking it may the stove.
to find out what a hot electrical accessory smells like, buy a cheap electrical item such as a brown junction box, and put it on the stove. They are made of thermosetting plastic which does not melt when it gets hot, but it discolours, chars and smokes. See if the smell is the same.
if you can't find an overheating electrical accessory, there might be a junction box hidden in a wall or ceiling; if it has a poor connection inside it, that can cause overheating. Here in the UK junction boxes are not permitted to be hidden in walls or ceilings in case this sort of problem arises. An ionising Smoke Detector alarm may go off if placed close to the source, or above it.
I had something like that once upon a time. Everytime I put the immersion heater on the smell got worse. The house had just beem re-wired and the electrician hadn't secured one of the big mains wires properly, it wasn't making a good connection and the plastic was getting hot.
Dad says probably mold or snakes!!!!!! I am completely freaked out. Anybody know how to kill mold or get snakes to leave?
