G
geraint
my colleague has listened to the bricklayers 50mm cellotex specified with a 100mm cavity they have full filled with 100mm rockwool. am i right or wrong saying no..
i was after an answer of the properties.. not a discussion of the ins and outs...You're right!
It could get wet (it could not but why chance it, once it's in there it'll be a b*****r to remedy)
Why have they done this? Penny pinching? Using up mats from another job?
Maybe you should have made the question clear to start with?
Properties?
That would have been one of mine then, I personally thought it was a valid response to and illogic post, by an ignorant member.a meaningful title has been added and some abusive or ill-tempered posts removed
But hey ho, I will stand by your judgement!
In my opinion Dritherm cavity batts (100mm full fill) is the simplest method by far.
They do not wick water.
...and you can set the brickwork (external leaf) out first.
I personally thing partial fill rigid foam is pants!
