Not sure if this is the right section, but anyway...
I really could do with a second shed in the garden as the other one is over full.
We have a spot which is wasted and fairly hidden so would be a good spot to put it in, the problem is the size and shape and location of the area.
Basically it's a large step behind the garage. The area is about 8 foot long by 3 foot 10" wide. I wanted something about 6' x 4' but its not quite wide enough. Also with it being right behind the garage I wanted the roof to only slope one way like a lean-to rather than an apex roof.
The wife's not to keen on me building one as she imagines the bodged kind of farm lean-to's you see. This would have to be well built and professional looking. She would much prefer that I find one that fits but I've searched and can't find anything.
I've drawn up a couple of rough sketches of how I would like it and have a few questions...
The shed will be for light storage of things that would otherwise be left in the garage so it doesn't need to be 100% weatherproof. The ground is concrete with a mains drain slap bang in the middle. Would I be OK to build a shed with no floor so the inspection pit cover is inside the shed? (Obviously I take the risk of it over flowing)
As the shed is right next to the back brick wall of the garage can I use that as the back wall? ie screw the battons straight to the wall so when you go inside the shed the brick wall can be seen inside the shed? Or should the shed be built separate with an air gap between the garage and the shed?
I was going to go for overlap for cheapness.
Any thoughts or advice?
