Hi
I've recently installed a shower pump in the airing cupboard next to the hot water cylinder and need to feed power to it.
There is no spare power supply or socket in the vicinity, so I was thinking of using a spur from the immersion heater socket.
The spur is going to run a double 3 pin socket to run the shower pump (via 3 pin plug) and occassional vaccum cleaner through the other 3 pin socket).
When I opened the face plate of immersion heater, I found that there are 3 red and 3 black cables at the back side. Does this mean that its already feeding a spur? If yes, I don't see that spur.
What would be the best way? Should I put a junction box in the gray cable that is running to the immersion heater socket and make a spur from this junction box?
Is this allowed/ OK or do you have any better suggestions?
Also if someone has any helpful information/ links to posts on here or elsewhere, it would be great if they can share that.
Thanks for your help in advance..
P.S. I will post a pic tomorrow of the socket in question..
