Could some kind electrical expert possibly help me solve a problem? In the inner hall of my bungalow I have a 3-gang 2-way light switch that operates a ceiling light in the inner hall, another one in the outer hall, a light in the loft, and an outside light at the corner of the bungalow. One 3-core and one 2-core cable (not counting earth wires) come into the switch box. The red and black of the 2-core cable are connected to the Common and L2 terminals respectively of the the right hand switch . This is the switch for the loft light - no problem. The red and blue of the 3-core cable are connected to the Common and L2 terminals respectively of the left-hand switch. The grey of the 3-core cable is connected to the L2 terminal of the centre switch. A short length of red cable joins the Common terminal of the left-hand switch to the Common terminal of the centre switch. The left hand switch operates the inner hall ceiling light. The centre switch operates BOTH the outer hall ceiling light and the outside light - i.e they cannot be lit separately.
My problem is that I want to be able to switch on the outside light without having to switch on the outer hall light. Ideally I would like to change round the wires so that, say, the left-hand switch turns on BOTH the inner hall and the outer hall ceiling lights simultaneously (no problem if they both have to be on at the same time), while the centre switch just turns on the outside light. Failing that, I would be happy to substitute a 4-gang light switch for the 3-gang one and wire one switch separately for each light. But I can't figure out how to connect the existing wires for either option. Is either feasible without having to cut another cable channel down my wall?
I assume incidentally that whoever installed the switch used the L2 rather than the L1 terminals just because they were easier to get to - it seems to be set up for 1-way not 2-way switching.
I can't see any sign of any other intermediate switches.
