Hi, on the internals of extension/gutting of small cottage and trying to find out whether it is possible to have two heat sources on one system - one would be a back boiler on a solid fuel stove the other proposed heat source being an oil fired boiler for convenience. Advice I have received so far has been conflicting, both in regard to system that switches between these two sources and for one that passes water through one then the next.
Basically is this possible and allowable within regs?
Cheers
Cheers
