I would like to add some lights and power skts in the loft to use as a computer / office room
In total i'd need around 4 x 60w lights & 15 skts (mostly for small wattage transformers)
In the loft in a now unused 10mm supply cable that was used for the old electric shower. (own fuse in main consumer unit)
My line of thinking is to use this and then connect it to a 2 way consummer unit and run two ring circuits from it one for lighting 6amp & 10 amp for the skts. I was thinks of installin multiway 5 x three way sockets.
Is this the correct way to do things? Is there a better idea.
I'm pretty confident in DIY electrics and I will be getting the 10mm cable connection to the new consumer unit fitted & all my work tested by a pro.
I just want to do the donkey work myself
Have I forgot anything? Any help / advise is more than welcome
Brian
Brian
