hotpoint wm64 washing machine will not start,
27 Aug 2010
no lights on looks dead, but have power to on/off switch, live feed then goes to door interlock this is where i get a bit lost!!
door interlock has 3 wires, live in,netural,comm,
when i joined the live and comm together the machine fires up,
have replaced the switch but still no go, same problem, pcb maybe ?? any advice would be great many thanks!!!
have multi-meter and sledge hammer 50/50 fix it kill it !!!
check the pcb for broken track on the netruel supply ,also check the netuel on the on off switch.
Spot on the netural track on pcb board has near on gone !!
would it be ok to cut wire on connector block and solder it to the point on the board? or its £100 for a new board
U can or u can solder a copper wire over the link that's broken.
