S
snadge
ive realised that when i plasterboard the wall with the other door on in kitchen that the lining is gunna have to be replaced...as the board wont run flush to the lining - i was thinking I could add a 10x30mm piece of wood all way around for the board to run into and re-hang the door 10mm forward on the new bit of wood and move the stopper forward 10mm (or add more wood 10mm)
is this "adding strips of wood" a viable solution? or should i replace it with a bigger one? (if i can get one as the current is currently 140mm wide so would need 150mm)
thanks for the help guys
