M
mysteryman
I think it should last longer. Most houses are plumbed in it with copper tails like yours and mine are.
Hep20 has been around for 15-20 years now. Its predecessor was Acorn, which was dark brown, and that was first in use getting on for 30 years ago. They are excellent - as long as there is an insert AND the pipe is fully inserted into the fitting. The fittings will go straight onto copper, and you can get special O rings for 3/4 copper.
Thanks mysteryman, this stuff sounds briliant. Is the lifespan expected to be as long as copper?
It should outlast copper. Although my only suspicions will be the rubber O rings that will perish well before the plastic pipe. Also anything less than barrier pipe is pointless regardless if it is being used for heating or not.
IIRC hep comes with a 25yr garauntee.
I have fitted in the last 5 years no less than 100 new build houses with the stuff, its amaing, never had a call back yet.
Reduces sludge, friction etc etc. Very good to install/work with. Alot better than speedfit IMHO
