3 port valve - how much play in spindle?
13 Feb 2009
Hello,
Lot's of great, informative posts on here have inspired me to attempt to resolve a 3 port valve issue:
Siemens MA-V322C, 3 port valve, approx 9 yrs old.
Worked well for years, then buzzing noise started for a few months and eventually had to use the manual override lever on an ad-hoc basis (as many others appear to have done).
I've stripped the valve head/body away from the pipework and noticed the spindle only moves approx one eighth of a turn in either direction - is this normal?
Plan is to fit a replacement body/head - just wanted to check the 3 port pipework & spindle behaviour is normal, any advice much appreciated.
Hello,
Yes, they have very little 'play'. Just change the head.
Now, I dont want any thanks, but if you fancy selling me Chelsea for a bag of potatoes and 2 shillings Id be eternally grateful.
Thanks for the confirmation.
Another q.....
I see the 3 port valve as being three components:
Head (grey plastic box housing motor, with rachet cog visible)
Body (having manual override lever, microswitches, two or three springs)
Pipe work (T shape pipe junction containing valve spindle)
Am i correct in my understanding?
Do i need to replace the head only, or the Head and the body? (the body component can be unscrewed from the pipework).
pointless changing actuator,they can be just as expensive as a full new 3 port valve,it will probably end up passing in which case u would have to change whole valve,bite the bullit and fit a honeywell 3 port valve and u wont have anymore problems :)
thanks both for responding - will consider honywell next time.
I ordered and received what was described as a 'replacement actuator head' for this model of valve.
Only the grey plastic box containing a motor and visible cog has been supplied - have i ordered the wrong part? I expected to receieve the secondary component (microswitches, springs, lever etc) aswell!!! Have i been ripped off?
I had already stripped back to the pipework, in expectation :shock:
never changed a seimens actuator b4 2 be honest so couldnt answer ure question but actuators as a whole should come as a complete unit and normally u should just unscrew the old and fit new,like i said u are better off returning it and getting a honeywell,check to make sure the brass body of the valve hasnt seized up....this can cause the actuators to fail as well,again this would need a new complete valve :)
