if you feed a busbar ( the type for linking breakers together in a panel ) from the center intead of one end, does that double it's rating?
if for example a 63A busbar had 100A worth of breakers ( 5 x 20A breakers for arguments sake ) and was fed form one end, in theory you will be pulling 80A through the busbar at the feed end if the breakers were all loaded to capacity ( 4 x 20A remaining, the first breaker wouldn't draw current through the busbar )
if you feed it from the middle then you would have 40A each side ( again the breaker being fed wouldn't draw through the busbar, so 2 x 20A each side )
