The Infamous Potterton Profile 50e
Because you need a new pump :wink:
Hit the old one with a hammer a few times and see if it starts turning. It might but i doubt it.
ok, i'm looking to get the pump changed this weekend, however, i refuse to go out without a fight.
The boiler keeps tripping, which from previous replies to the thread leads me to think there's bad circulation. I've drained a bit of water out of the bottom drain valve while keeping the top tank tap filling up. Also what leads me to this is when I detrip the boiler, when it fires up you can hear the water boiling inside the boiler, like there's not enough water in there!?
Has any one got any ideas? Can the feed in to the boiler from the top tank get air locked on entry to the boiler? Is there a bleed valve on the profile 50e?
Really appreciate the help peeps.
Dan
:roll: We established long ago that your system has poor circulation, and replacing the pump with one that works will make a big difference. Stop fannying about and get on with it.
Once you've got the new pump, the water will be circulating better. If you can afford an extra £100 or so, get a Magnaclean fitted at the same time. This has a magnet that traps circulating particles of black iron oxide sludge (there is usually a lot of this in an old open-vented system)
After the pump is fitted and you are satisfied there are no leaks and it is filling properly, add a litre of Sentinel X400 (which is a very mild sediment-loosening chemical) and let the pump run through the radiators for 4 weeks (even if the weather is hot and you need to turn the boiler stat off or down)
You will know it is starting to work when the circulating water goes jet black (you will see it collecting in the Magnaclean if you have fitted one)
After 4 weeks, drain it out and rinse it to remove the loosened sediment. Add a litre of Sentinel X100 on final fill to prevent future corrosion. If you fitted a Magnaclean you will see it continues to collect more black sediment for a year or more, even though you thought you had drained it all out.
If the boiler still makes kettling noises, it may be limescale. Add a litre or two of Sentinel X200 and leave it in (do not drain). If you close off some of the radiators first, it will be more concentrated when you are running HW only, so will work faster.
The chemicals will cost you about £15 each from most DIY sheds or plumbers merchants. Avoid cheap brands. Also avoid aggressive chemicals or acids, they have their place but need a lot more care and can't be left in for long.
You know you have to scoop out the mud from the F&E tank, and sponge it clean, before draining? And you know that before adding chemicals, you tie up the ball float in the F&E and drain a couple of buckets out of the drain cock? So that when you untie the float after stirring in the chemical, it will be drawn down into the system.
I am a householder not a pro.
X800 is said to be faster than X400 but I have not used it.
During the warm weather, after draining out the X400, would be a good time to fit new rad valves and TRVs and new bleed nipples where needed. It saves draining down again later. You can do this yourself.
John you are a legend, thanks for all the help. I didn't know that about the top tank, will have a bash at this over the weekend.
Thanks again,
Dan
Hey John, after a summer of not neediong the heating I've finally got round to nuying evcerything I need including a magnaclean. It says the magnaclean needs to be on the return pipe to my boiler. Am i right in saying the return pipe shoul;d be the one that's cold?
GALLERY]
The attached picture is the boiler in question, the right pipe is warm, th left pipe is cold !!?
Check that your cold feed into the system from the feed and expansion tank is not blocked. Your speed adjuster will be a 3 position switch on the box which is [incorrectly] underneath your pump. If you fit a new pump, and the electrics have to be underneath as in the photo, you should reposition the head on the pump body so that they are on top.
Firstly thanks for all the replies!
Mystery man, thats the first thing i noticed with the new pump, when it's fitted all the electrics will be at the top of the head so that's a good start.
yes check the pic i posted the flow is on the left that should be the hotter pipe
unless they are crossed over above the boiler :wink:
