Evening all
Just noticed no pressure on the boiler gauge, repressurised it to 1.5 bar, then water started dripping. Found it to be coming from the body of the expansion vessel(pinhole). My questions are:-
1/ Where can I buy one cheap?
2/ How difficult is the replacement? I've recently done the divertor valve, how does it compare to this?
3/ What is the procedure? Manual says....air press switch, fan, flue hood, overheat thermo, central heating sensor, burner, auto vent, gas to water exch, water to water exch, water pump then the exp vessel itself. Seems like a lot! Are there any shortcuts? I do have access to both sides.
4/ How do I repressurise the exp vessel?
Thanks for any sort of help.
Craig
Craig
