In the UK there's no such thing as 3 way switching.
If you want to control a light from 3 (or more) positions, the term is two way and intermediate. And the live and switchline can be at opposite ends of the switching circuit.
The live feed and switched live should be at the same end to avoid setting up eddy currents around the house.
The live feed and switched live can be connected at any point across the two strappers (usually L1 & L2). They can be connected at any switch in the chain, even the intermediates.
The live feed and switched live should be connected at the same position or switch in the switching system to avoid setting up eddy currents around the house.
You are talking complete and utter bollerx, eddy currents will never cause a problem in any installation using T&E cables.
You're out of your depth and drowning.![]()
An eddy current is a circular magnetic flux running around cables not houses.
How can you have eddy currents running round a house?
Are you getting confused with capacitive coupling?
Getting back to the topic, if the live feed is connected to one end of the 2Wint system and the switched live is taken off the other end of the 2Wint wiring and not routed back along with the strappers, then a significant magnetic field can be set up.
Whats '2Wint' mean? I thought it was typo but as it appear twice I assume it is another revelation.
You're talking nonsense.
So if my car won't move tomorrow it could be due to the significant magnetic field running around my house.
A classic example would be if the live feed were picked up from a downstairs ceiling rose and the neutral were were picked up from an upstairs ceiling rose [ignoring the possibility of a borrowed neutral.
Sorry, these are some of the craziest things I've ever read.
Edit: Just had a look at the link, silly me I did'nt realise that lighting circuits carry 1000's and 1000's of Amps.
