I use chrome plated copper stubs if i do towel rails and find it so much quicker to anneal the pipe and flare it and slap an MF / street elbow into it, there is no chrome removal involved.
Thanks for that, have you a link to them OR what name do they go by?F and r from behind the centre of the rad is the way forward.no pipes out the floor,no need for exact measurements of tad size,projection etc on a first fix.only minimal pipe work on show at the rad valve
If your going for a F & R from behind the rad and the wall is rendered not dot and dab what method are you using to terminate from the wall to the rad, or is it out of sight out of mind![]()
Cheers Mick.
I could fit false stabs through the floor just to give the Wife something to aim for.If we're altering/moving/installing new rads and there building work or a plasterer on site I wouldn't pipe a rad any other way.
Just done a 20rad house and the guy loves it as there no pipes coming out the floor to his rads,less things for the wife to hit with the Hoover apparently
