Retrofit tile vents?
4 Apr 2008
Hertfordshire
I've been asked by building control to fit tile vents to my extension roof (I thought the soffit vents and breathable membrane would be sufficient...).
I've had a quick look around t'internet and found some plain tile vents; my question is how do I go about retrofitting these? And also, how high up the pitch should they be positioned (if it matters)?
Thanks for your help :)
Remove a tile, cut the membrane, fit the vent tile. The meerkats have a word for it
They should go as high as possible
If you have used Tyvek, then they have produced a document certifying that additional ventilation is not required. May be useful, or consult the membrane manufacturer
Alternatively (and visually better), if you have a mono pitched roof, see about some abutment vents instead
Thanks Woody, sounds like an easy enough job.
Building control are aware of the membrane that has been used, but are still insisting on extra ventilation.
Think I'll go for the tile vents rather than abutment vents as seems like they'll be easier to fit than cutting through a cavity wall. Also found some vents that match my plain concrete tiles pretty well, so hopefully won't have too much of a visual impact.
