macerator toilet can they really be that bad!?
25 May 2008
Kent
we are currently moving a bathroom and have been told that our only option is a macerating toilet. all i seem to read is that they are dreadful and at all costs don't use one. but what if you just have to??
what would be the best one to go for?
surely they can't be that bad, ( or they wouldn't make them?!) can anyone reassure me (please)
If your looking for reasurance about fitting macerators ask some one who has went in to repair them. To be honest mate if they have constant use of say 4 or 5 times a day they last about a couple of years before they develop faults . They are noisy beyond belief , Try using one after everyone is in bed . better off with the potty under the bed if you dont want the whole house roused. said before they are the invention of the devil himself. But hey this is only my opinion someone out there must like em.
thanks for your reply, and i hear what you are saying.
but surely someone out there has had a good experience?
This was written on another website, if you still want one after reading this, go ahead. :LOL:
Sell the house, failing that give it away, if that doesn't work pay
someone to take it or burn it down.
To give you a clue - these ghastly instruments of the Devil are
French. Add the French and lavatorial engineering - now see why I
say get out while you can. Moreover this particular Frenchman was a
lunatic with strong Anglophobic tendancies and a bad case of
coprophilia.
I am quite sure the designer was also an ex-submariner Frenchman who
missed the strangled screams of seamen who had got the valve sequence
wrong in the submarines toilet and just been rinsed down with a few
gallons of seawater (and the recently donated contents of the bowl).
They break down at the slightest opportunity. The only thing you can
actually guarantee about them is that they will break down - very
frequently.
Basically the only way of maintaining the slightest semblance of
serviceability is to impose on pain of repair the same rules as for a
small yachts sea toilet - if it hasn't passed through you it doesn't
go in the bowl.
They have an interesting design. The motor has poor starting torque
and the macerator lots of tiny teeth. Ergo anything that has strands
in it catches on the teeth and stops the motor from starting. Things
with strands include anything with cotton wool (including cotton wool
buds) and anything with cloth. Females in particular must not be
allowed anywhere near these devices. If you were unfortunate enough
to have the added misery of a sink (oh dear - you were) then add
hair, strands from wooly pullovers and almost anything else thats at
all fibrous.
When they break (which they will - that's an absolute certainty)
their endearing characteristic is that you are left with a bowl full
of whatever which you have to empty back the way it came and more
importantly many feet of 40mm pipe still full of minced whatever.
When you disconnect the pipe I'll give you one guess where its going
to go. Repairing or unblocking them is the most thoroughly revolting
job.
Now to get to specifics - the pulsing is a fault in either
installation or the pressure switch. Does it pulse with just the
cold water tap running from the sink? The way they work is a low
pressure trip switch switches on the motor when the small holding
tank is full. This tank remains partially full all the time. If its
pulsing either the switch has too low a hysterisis or water isn't
getting into it fast enough. The motor should remain on for a few
seconds after everything has emptied so that pulsing you are seeing
shouldn't be happening.
As the failure rate of these diabolical things is worse than that of
a F104 Starfighter I'd suggest you get the installer back (preferably
to remove it forever). If it was installed by yourself then self
flaggelation with a few lengths of barbed wire and a call to the
Saniflo people might be in order.
>Also, my system is a Sanitop with the outflow from a washbasin going
>into the top of the unit. I find that running the tap for a few seconds
>activates the Saniflow. Is there any way of adjusting the sensitivity of
>it so that it will only run when a reasonable amount of water has gone
>into the unit.
No, but if its oversensitive this might be related to the pulsing you
are seeing.
>I dont see why the washbasin water cant just bypass the
>cutter/pump internally.
Because these horrors are designed to be installed pumping upwards -
the raving idiot who designed them thought it would be pretty neat to
have something you could stick in a downstairs cloakroom and run the
pipe upwards to join the soil stack in the bathroom. If that's how
your installation goes cut out the selling the house bit - just burn
it now. When it fails there is 10ft of pressurised whatsit just
waiting for that final turn on the drainpipe.
The other reason the sink must go through the pump is that the outlet
of the thing is at some pressure. Connect the sink a bit downstream
and every time you pull the chain the contents of the loo make a
pretty little fountain out of the sink plughole (I've seen one
plumbed like that - the owner kept a sandbag in the sink on top of
the plug).
Some models have an interesting feature - on the top is a reset
switch, under the top cover is a screwdriver slot on the top of the
motor drive shaft to allow you to clear the (frequent) blockages.
However to get the top cover open to get at the drive shaft to free
it - you've guessed - you have to disconnect the drain pipe.
How they can be called Saniflow when they are anything but sanitary
(as you will soon find out) and rarely flow is beyond me.
As I said - sell the house.
well that hasn't made me feel any better!!
Lol
I would get a different plumber to look at the problem.
Theres very RARELY a problem of this type that cant be solved with some intelligent input and some ££
Maybe they will have a solution to get it connected to the main soil stack
A friend of mine owns a hotel with 2 macerators in the basement.
He jokes that he may as well reserve a space in the car park for the plumbers van!
Nothing but problems.
I have one, it failed after I had been in the house for a month.
Now it just fills with water then pulses al the time.
I temporarily put a switched spur on so it can be turned off when finished with, but we have to flush twice as the toilet soon fills with the water coming back.
I shall prober ably change the downstairs loo into a cupboard instead.
thanks everyone for your comments and scary toilet stories.
we have re-thought the macerating toilet and we are going to spend the time and money on fitting a normal toilet. hopefully we will manage it.
providing nothing goes down them that hasnt passed through your body first - they give around 7 years faultless service.
The problem is that people put all kinds of unspeakable things down the loo and expect them to just disappear and I guess that in the case of a macerator, then it just cant cope.... Need more horsepower.
I fitted one for a pal who was too tight to move his soil stack. He is under strict orders not to call me if the damned thing blocks up, especially since he made a song and dance about me using 1 !/2 inch waste when someone on the internet told him to use 3/4 inch overflow pipe....
Yes I agree with them.
Now when it blocks up theres going to be alot more crap store in that large pipe :LOL:
I fitted one in our garden out house 4yrs ago.
No problems.
If it did have a fault i will inspect it and service the unit myself.
This is the best advice I on living with these things if you have to. May be worth leaving a note when guests (especially female, who have endless items to throw down toilets from facial wipes to sanitary items) are round with respect to that!
I recently discovered I have one, discovered mainly due to the aforementioned reason. Other than that I was not aware I even had one in terms of noise (it is behind a false wall).
I agree with the earlier post.
Saniflo is the devil incarnate. We bought a house with two of the damn things but didn't realise what misery they were going to inflict on us.
Anyone who writes a positive post on these things either works for the company or has never had to open the lid on one to repair it.
If you can't install normal plumbing buy a potty and forget about installing these things unless you want your bathroom full of unspeakable things on a regular basis and establish a second mortgage on plumbing bills.
If you have too much money and time on your hands and have masochistic tendencies, try getting a non-saniflo plumber to monkey around with one of these things and watch him swear, tear his hair out and charge you like a wounded bull trying to figure it out.
NIGHTMARE !!!
CAVEAT EMPTOR
