Moved into a house recently. It's got two styles of Twyfords WC - both closely coupled bottom entry, bottom external overflow, front lever models.
I want to replace both styles with new innards, including internal overflow. Talked to the technical support at Twyfords, and was advised that - although I could replace the syphon with an internal overflow version - the toilets (specifically, the sump) were engineered for 7.5 litre flushes, and doing so would result in only 6 litre flushes, which might not be successful.
In looking at these forums, it looks like I can actually get a modern, internal overflow, syphon that can be set to flush at 7.5 litres.
Is this correct ? Has anyone else had experience of the modifying the Twyfords range (think this one is a Chantelle, which they no longer do) with a modern syphon successfully ?
I'm thinking of replacing with FluidMaster components. These should fit, right ?
