if your discharging a UV to waste pipe there is specific guidelines. It MUST go into a hepvo trap, theres no alternative. The price for the adaptor includes the trap as well.
http://www.nhbc.co.uk/NHBCPublicati...ical/StandardsExtra/filedownload,34921,en.pdf
The discharge is classed as part of the installation and "technically" should only be installed by a competent person.
If you block the discharge you make it dangerous, if you block the hot water draw off nothing comes out the tap. thats the difference. Not that I'm suggesting your going to block it, just trying to explain the difference.
