I have seem to have lost control of the water side of the programmer/timer
The system is working but only on the (CH) side I have carried out some checks and it would be helpful if somebody would comment on them or advise further test I could carry out
checked the 3 port M valve and it travels when current is applied
checked copper cylinder stat and voltage is present , circuit broken when the micro is pressed (not sure if this is working the right way round )
if the room stat is backed right off (so there is no call) with the programmer status ready for call, then the M valve remains is CH position, it does not return,
if the room stat is backed of ( so there is no call) and the programmer status is off then the M valve remains in CH position
If i kill the power to the programmer then the M valve Returns to its HW default postion
Seeing that I do not here the relay in the timer click for the HW side but can here on CH side I am thinking it is the Programmer but would like to try and confirm this before I purchase a new one
the model of the programmer is drayton lp722 (looks identical) not sure if drayton bought out lifstyle as my programer is badged lifstyle
