cutting pipe
iep
5 Apr 2010
Very basic question but, where there is no space for a proper pipe cutter to be used, is it okay to cut copper pipe with a hacksaw?
Obviously the saw will cut the pipe but will the imperfect cut compromise the seal on a compression fitting subsequently fitted to that pipe?
Cheers,
iep
It will be ok so long as you do not damage the external surface of the pipe that will seal with the olive (compression ring) and the nut and olive slide right over the pipe
  • Thanks
Reactions: iep
Thanks. Makes sense. Just wanted to be sure.
Cheers,
iep
The imperfections @ the tip of the cut can be removed with a ******* file :idea:
  • Thanks
Reactions: iep
Maybe actually. I might pick one of those up (or similar) when I buy the parts.
Cheers,
iep
