Metric to Imperial
  • Thread starter Thread starter GaytonTonner
  • Start date Start date
G
GaytonTonner
I have some old 1" imperial copper pipe to connect onto to using end-feed fittings. Do I need a 28mm to 1" adapter? Who would sell these?
On a general note does anyone know what sizes need a conversion adapter and what do not.
What about compression fittings? Do they fit each equivalent size?
1/2" to 15mm none required
1" to 28mm none req
3/4" TO 22MM Adaptor req
Compression fit the same but on 3/4 you can get a 3/4 olive for the 22mm fitting but a copper olive will work just aswell
1" to 28mm none req
Thanks. So only (3/4" - 22mm) is there an issue on end-feed copper? Just to clarify.
I know 3/4" imperial olives are available for 22mm compression fitting. I would be weary of using a 22mm copper olive with 3/4" copper pipe. That is just me, I would not trust it..
Maybe this information should be in a sticky.
Don't use 22mm olives on 3/4! You can also get 3/4 O rings for some pushfit fittings.
You may need to file inch copper down a bit to get 28mm fittings on to it.
This 1" copper is fitted and not in a position to file down. :(
