Hi Could some someone please help with the following:
I am looking to run a supply to an 600W macerator and a 3KW heater located within a toilet/shower room in an out buildng at the back of the garden. There is already a 30mA RCD protected board with a 20A spare way. I'm looking at supplying the macerator and water heater from the same circuit and run it in 2.5mm twin and earth however I have a couple of questions.
1. Can I install fused connection units within close vicinity to the sink and the toilet or would it be best to locate them outside of the room.
2. I have a couple of wiring diagrams in my album and would appreciate if you can have a look and see which would be best baring in mind I'm aware the water heater would be close to the 13A fused connection unit.
Apologies if the diagrams are a bit crude but, hopefully they will give you some indication as to what I'm proposing.
Any feedback/help would be gratefully received.[/img]
