I have recently had a new boiler installed (July 2010) and have only just released that the boiler is running either the CH or HW function one at the time and not both together.
I have got the DT20 timer, and have setup my program as follows:
HW:
M-F: 06:00-07:00 | 17:00-18:00
S-S : 06:00 -07:00 | 17:00-18:00
CH:
M-F: 06:00-08:00 | 17:00-22:00
S-S : 07:00 -10:00 | 16:00-23:00
I have the following CH/HW setup:
Boiler:
WorsterBosch Greenstar 30DCi Boiler (60/100 Horizontal Flue)
DT20 Timer | Intergral Diverter Value
HW Cylinder:
GLEDHILL 1500X450 INDIRECT COPPER CYLINDER
POLYTANK LOFT TANK 64X24X19 70G
Stuart Turner Monsoon Standard 3.0 Bar Twin Pump
Installation Layout:
S-Plan:
When I walk down stairs in the morning (06:15), the boiler is on and is heating the HW Cylinder (readout displays 85 ish) but the radiators are cold, if I press the “advanced” button to turn off the HW, the readout goes straight down to 30-40 ish, then the boiler kicks in about 2 mins, then starts heading the radiators…
Is there a problem with the diverter value?, as I was under the impression that the boiler could heat the HW cylinder and CH at the same time?
If it can’t then I will just have to re-arrange the HW & CH times, so they don’t come on at the same time
(My old Potterton NeatHeat 10-16 could)
Cheers
James
HW:
CH:
Boiler:
HW Cylinder:
S-Plan:
Cheers
James
