I plan to replace two old CUs - 2 X Wylex 6way, wired fuses. I have to replace the CUs with two modern ones. Should I get two units with twin RCDs ? or two units each with one RCD and a non protected section.
I would like to have the fully RCD proteced option but could this cause a lot of false trips ?
( this will be contracted out to an electrician - just planning at the moment).
Current set up CU1 - R1, R2, L1, L2, Immersion, Garage Power (original house)
CU2 - R3, R4, R5, R6, L3, Cooker (extension)
A lot of ring mains I know but I can't change the set up as the cables are in walls and under floor. Cables are all PVC.
Thanks for your thoughts
