I've just built a brand new bathroom. With advise I was told the simpliest way of wiring the extract fan and light to a pull cord (these are the only demands on this circuit) switch (maybe a double pole pull cord?) was to use lighting cable from the extact (which only had a L and N terminal (brand new)) to the pull cord switch (this has a N and L for 'supply' and a N and L for 'load'. I assume supply is from the consumer unit/fuseboard, and the load was the extract. I also want the pull cord to turn the light on and off at the same time the extract. I therefore have put the lighting cable from the ceiling rose into the 'load' terminals along with the extract cable.
Now once i restored the power the light comes on and off as it should, but the extract fan does do anything.....why not? Everything is brand new.
Thanks for your help in advance
S.
S.
