I am having a single story extension built. The builder is making it water tight, the rest i am doing to keep costs down.
I have a plasterer to do the plastering but i want to do as much prep work as possible. I want the plaster to be the base coat and finish type and not the dob and dab plasterboard and skim
The back wall of the existing house is painted, and this needs to be removed before plastering. Whats the best and easiest way to remove this paint, someone told me you can get a bit for an SDS drill to do the job. Does anyone know what this tool is called
Also the radiator heating pipes shall be covered by the plaster. I am guessing these need to have some sort of cover over them or the constant heating/cooling of the plaster from the heating pipes will cause some problems. What the best covering to use?
