Stuart Turner Pump
Hmm Right you are.... I'll have to leave it to the New year when they return and I can speak to them.
Many thanks
Stuart Turner are just round the corner from me, they were shut at 2:30pm today. In a few minutes I'll be off to the Bird in Hand - just across the road from the factory - if any of the ST guys are in the pub, and still conscious, I'll have them go back to work :lol: :lol:
Technical Specification
The Pump
Hot & cold inlet strainers
Stuart hard face mechanical seal
Flow switch sensitivity approx. 0.6 l/min
Pressure switch
Max. inlet head 8 metres
Plumbing connection G ¾ " male
Flexible hose G ¾ " female x 22 mm push-in c/w isolating valves x 305 mm long
Anti vibration feet
WRAS approved
The Motor
Power Supply 230/1/50
Enclosure rating IPX4
Motor Induction type, permanent capacitor, auto resetting protective thermotrip
Power consumption 435 Watts
Full load 1.9 Amps
Fuse rating 5 Amps
Pre wired
Rating Continuous (S1) @ 9 l/min and above
Gross weight (packed) 9.2 Kg
3 Year Guarantee Can be extended free to 5 years -United Kingdom only
Part Number: 46480 (United Kingdom specification only)
Performance Curve
It probably stated Phase/Frequency beside the box where the numbers are stamped, then the box 1 50, then after the box v then another box 230
So
Phase/Frequency (1 50) V (230)
No - the OP assures us it actually says
"power supply = 230v (phase frequency 150v) single phase"
James - could you post a photo?
I'm wondering if it's a counterfeit product, made by someone who doesn't have a clue...
