Hi all hope you had a good Christmas? My combi saunier duval sd30e is loosing pressure and the DHW doesn't work most of the time, until I fill the boiler up with the filler loop.
After searching around I believe there must be a leak somewhere? It can't be upstairs as I would see the leak from gnd floor. Is there a solution that can be run through the CH to stop the leak? I have carpet in 1 room and large floor tiles in the other room and it's not going to be to take this up. Please help thank you.
