I posted this in the plumbing forum without reply thought it was the best place but obviously not can you boy helps I am not overly clued up on boiler controls
My old boiler timeclock with stat is playing up and I want to replace it it has no makers name but says VRT-QT under the cover
It is wired in 3 core and earth as follows
Green/yellow is neutral side of timeclock or terminal 2
Red is terminal 1 or live of timeclock
Yellow is wired to terminal 3
Blue is wired to terminal 4
I want to replace this with a honeywell ST699 programmer and T6360 wall stat but am not sure help
Boiler is a valiant vcw 282 gb
Forgot to say boiler is a combi so no hot water control required just need a stat to regulate temp and a clock to override it when heating is being called for out of timed hours
Many thanks in advance as always
