Landing hall light has 2 switches that operate it (rocket switches) - 1 in hall and other on landing - is the wiring for this the same as normal 3 plate wiring, with just an additional switch wire (L and SL) to the other light switch?
You have a 2 gang switch that operates 'rocket switches'Landing hall light has 2 switches that operate it (rocket switches) - 1 in hall and other on landing
I assume you mean a three gang switch and the answer is, it depends on whether the switches are one way, two way or intermediate.is the wiring for this the same as normal 3 plate wiring, with just an additional switch wire (L and SL) to the other light switch?
sorry may sound idiotioc - a two way switch is one what switches 2 lights or is it a switch that has a common terminal and a L1 and L2 (or is that just a double pole)??![]()
one last question please if I may: what exactly is a short circuit - is it where the live and neutral conductors touch due to a fault - and blow the fuse?
