- Joined
- 5 Jan 2011
- Messages
- 1
- Reaction score
- 0
- Country
Hi All,
I have recently replaced a shower pump for a family member and now it is a struggle to get a decent shower.
The original pump (nameless no ID plate etc) had been working absolutely fine supplying 2 showers without issue.
Since fitting the new pump which is a watermill and suitable for 2 outlets there is practically no flow when the heat is set high. If the shower is started on a colder setting there is a slight improvement. It sounds very much as though the pump cavitates when first activated. The plumbing has not been altered so find it difficult to see how the original installation can be at fault.
I am suspicious that the hot supply is draining back and that neither shower has non return valves. Would fitting a non return valves to the hold and cold at each shower or before the pump aid in keeping the pump full of water when activated preventing cavitation?
Any advice greatly received. Thanks
