I have the floor up in a bedroom above a kitchen.
I thought of filling the space between the joists with some kind of insulation.
The Victorian joists are about 16-17cm high and 30-36cm apart.
As space blanket is cheap, comes in 37cm width rolls and easy to install, I thought it'd be an economical way to fill the space between joists. Could do the whole room 3.9mx3.2m for 20-30 quid.
Would filling the entire space be fine, or is an air gap preferred?
I certainly don't want to to cause a mould problem.
There should be no condensation problems between two heated floors?
They seem to do 15, 17 & 20cm thick.
Or 15cm thick space blanket be better?
Would squeezing 20cm space blanket in there also provide a tad better sound insulation?
TBH sound insulation is probably more important than thermal, but not that important, so I don't wanna spend that much, hence the space blanket idea.
Thanks for any advice.
