OK, so at the end of last week i decided to change the bath taps (something i have been meaning to do for ages).
Being a rank amateur, i tried to 'turn off the isolator valve' resulting in the screw breaking off and a small leak developing..... No problem i thought, i'll just fit a couple of new ones.
So down to Screwfix i go, two new isolator valves fixed on, taps all fitted. nice.
I've been ill over the weekend so left the clearing up till tonight.
I now realise that what i replaced is a check valve (i thought it was some cheap s*** isolation valve...).
My question is, what should i do now? Do i need to re-replace them with double check valves (as removed) or can the system live without them? I understand what check valves do, so is there a risk (other than cold water coming out of the mixer shower) caused by back flow into the hot system?
Post your helpful answers below, and please, keep your laughter at my mistake to a minimum....
