Compression fittings and PTFE tape
27 Oct 2010
Sussex
Why do people insist on putting reals of PTFE tape on compression fittings? Had the father-in-law over at the weekend to help out and within 5 minutes he'd popped out to B&Q and came back with 2 rolls (yes .. 2 rolls!) of PTFE tape and a pot of that nasty boss green stuff.
I was always told to make sure everything is clean then hand tight plus 1/2 turn. This gives me a nice tidy joint an on the rare occasion that I get a small drip, another 1/4 turn fixes it. I can't find anywhere that says you should cover all the treads in PTFE ... so why do so many people seem to do it?
You're absolutely right, but it won't stop a lot of people telling you otherwise.
The olive needs to bite into the pipe to hold it in place and to form the seal. Adding PTFE tape might make a seal, but leave the olive 'loose' on the pipe. It's not good practice.
i perfer to use PTFE on the olive and make the joint tigher.
handtight and 1/4 turn is the best way to get a watertight seal but just doesnt feel tight enough for me.
in the early days when i didnt use PTFE a joint that wasnt leaking when fitted was 'seeping' when i came back to it over a year later.
I usually use a smear of Jet blue to be honest but have made many joints without any problems so no idea why you would waste time and money on PTFE ?
There are actually some doughnut web sites that tell you to put PTFE on the threads. http://www.diydoctor.org.uk/projects/copper_compression_joints.htm
On that same web site there is a little video, in this video he suggests that you tighten the nut 1 turn. In my book 1 turn is 360 degrees but that is far too much. He actually only turns the nut by 1 flat so maybe thats what he means, what do you guys think.
