G
GaytonTonner
Combi or System? It's largely down to your own preference. If you are considering an unvented cyl you are still utterly dependant upon your cold main flowrate to deliver everything in terms of water flow.
Correct. Some people on here think one these will improve water flow.
The only real difference between a combi and a system boiler is that the combi has a domestic water flowswitch and a plate heat exchanger. Neither of these components on their own will make the boiler significantly unreliable. You will need external extra equipment with a system boiler anyway.
Yep.
