Hi
I've done a bit of research on the subject but I was hoping to get another opinion to try and come to a conclusion on this...
I live in a 3 floor townhouse. There is currently an indirect system in place, but since the CWST, hot water cylinder and bathroom are all on the same top floor, there is no decent shower (flow is zero when you lift up the hose attachment we currently use). A good shower is a high priority for the wife, and rather than go with a twin impeller pump we're looking at fitting a combi instead.
My concerns with a combi are:
1) Do I have enough pressure? Two plumbers have read 2.5 bar at the kitchen stop cock. On paper that sounds like enough.
2) Currently, the rising main which fills the cold water tank will stop filling the tank if I turn on the kitchen sink cold tap on the ground floor. I'm concerned that if we fit a combi and everything is under mains pressure - will this mean that if someone is showering on the top floor and the washing machine kicks in, the shower will stop in the same way? Is it right to make the comparison as I have done?
3) Powerflushing: do I need it? It's a late-70s house, and I have nothing to suggest that the system has been "cleaned" in anyway. One plumber said I need it, the other didn't. Any further opinion valued.
4) I've been recommended the Potterton Performa HE30 by both plumbers. Any thoughts/comments? Does the combi "pump" the water in anyway i.e. perhaps to combat point #2?
Thanks, and sorry for the long post but the wife is nagging after a year of inaction so appreciate any advice received which will help me come to a decision!
