Pump over-run help please
29 Aug 2010
Denbighshire
This is the most simplistic and easy to understand wiring diagram i could find on the net ..
so i like it and understand it completely ..wish all were like it.
As, i have trouble following all the jargon initials etc on most diagrams
trouble is ..it hasn't got the pump over run circuit on it.
can anyone tell me what wires go where for the pump over run function ...and maybe pencil them in for me .
and I'll be good to go. :)
http://img.photobucket.com/albums/v190/aboard_epsilon/Y-Plan-Wiring.gif
all the best/markj
pump overrun will come from terminals in the boiler.
like this.
all the best/markj
The connections for the pump over run circuit will be found on the boiler connection strip, which should read L N E Sw L and Pump L N E. if there is no connections for the pump then the boiler as not got a pump over run switch.
spraggo
well you see ..what I'm trying to do is put the wiring in first ..i wont get the boiler until the summer
as you see on the diagram ..it has only three wires going to the boiler ..
i assume then .. that with the over-run ..i will have five wires going to the boiler ..so a five core cable will enter the boiler..is that right.
all the best.markj
are you saying i should just put the three core cable to the boiler and by doing some extra wiring jumper of some sorts it does its switching internally by itself ..
if you are, its just me not understanding it ..and how it works
and sorry .
i phoned Worcester Bosch up today and the guy was going on about 6 wires coming into the boiler from outside ..so i just got really confused.
all the best.markj
well 4 then ..but in a five core cable.
all the best.markj
I make it fire resistant 3 core and eath to the programmer and two core and earth to the pump. Which boiler are you getting they don`t all have a pump over run. Is it oil or gas?
spraggo.
i don't know what boiler I'm getting
it will either be a regular condensing valiant if it exists. Worcester Bosch or ..viessmann. 24 kw or there abouts ..it will sometimes have to heat my workshop as well.
its whats best value for money at the time ..the availability of spares..price of spares ..back up ..and subject to more reliability reports.
BTW ..some people here are going on about getting a temperature compensation thing ..
but Ive worked it out its no good ..due it being £150 with vat or more ..and probably not even paying for itself by the time the boilers life comes to an end .
all the best.markj
like this.
looking at your pic ..i still don't understand ...there are 7 wires there at the top coming in ..
three wires on the left i assume go to the boiler internal electrics.
not like my circuit diagram
or is the left one one the mains
and where doi the wires at the bottom go to .
all the best.markj
YEP that's almost perfect ..colour the wiring and it will be even better ..
now i can see i need a short 7 core cable from the boiler to the first intersections ..yes thanks thats helped a lot . :) happy
see i would like to print it out laminate it and stick it in on the wall , on the inside of the cupboard in which will be housed the pump, the divertor valve ..the plan box..once anything goes wrong ..i don't have to think to hard ..or go looking for it on the internet .
main switch has to be less than 2 mtrs from boiler at eye level ..is that right .
all the best.markj
hold on ..
i can see that the pumps earth and neutral can go directly to 2 and 3
meaning i can use the 5 core
is that right ?
seco are you Dave ..the original drawer of the diagram ..if you are ..big thankyou .
all the best.markj
Does this diagram help?. It shows the pump connected to the boiler via the wiring centre, so the earth and neutral connections for the pump are at the wiring centre, not at the boiler. You then only need a maximum of 5 wires to the boiler: Live, Neutral, Earth, Switched Live, Pump Live.
View media item 30148
Click to enlarge. You can then right click to save the enlarged version.
Are you sure your new boiler wont contain a pump? Personally, I'd just run a 1.5mm T+E and also a 3C+E cable between the boiler and the wiring centre. That way, you have one supply/call for heat and one spare for a pump, should you require it. Of course, you'll probably want to terminate the T+E behind an outlet plate at the boiler and bring it out on a flex.
If there's any chance the call for heat is going to require volt-free contacts, you should probably run in 3x T+E!
