Noisy water pump
25 Jan 2011
Lincolnshire
Hi guys, I hope somebody can help on this one, my central heating went off last night, boiler seems to working fine but there is a screaching noise coming from the water pump and pipes running from it are luke warm to cold, have turned it off for now not wanting to do any damage. Any ideas?
Remove the large screw from centre of pump, does the pump spin when turned on? with it move with the help of a screw driver?
Andy
You might have a blocked feed, (test the feed from the loft, normally 150mm from the pump.) Use a magnet and see if it sticks to the pipe work.
It helps if you can post a picture.
Andy
