I have laid some pex in concrete, only about 3sqm in total, and left the ends in a small cupboard which houses 15mm copper CH pipes (the flow and return for a radiator in an adjoining room)
Thinking of ways to connect up the loop, would a pair of these be worthwhile?
2 port manifold
Connect one to the flow, one to the return, connect the ends of the pex to one of each. Use the valves to control the amount of hot water passing through the loop (and to isolate if necessary)
I'll blank off the second port, and keep it as a spare for any future addition.
1) Does my plan make sense?
2) Would I need to have valves on both flow and return, or just one. (ie: could I buy one valved and one non valved manifold?)
3) No control for the heat in the ufh but only a small area so I'm not too bothered, and could always add control at later date on the plastic side of the system, right?
2 port manifold
