G
GeorgeBainbridge
delete
Using two Intergas combis is less than £2,000 to buy and they have weather compensation as standard as well.
No contest. Do your homework and add up the numbers.
Hi
Would like to ask your opinion on an idea (as stupid as it might sound).
I have 4 bedrooms, one bathroom with shower above, and extra shower room suite. I have been looking in many different direction to come up with a good idea to feed the whole house with heating as well as powerful showers.
A 30kw or higher combi seems not adequate to run both showers at the same time.
Unvented system will cost me over £3600+ (including a new boiler)
Normal vented system will leave me having to install a noisy pump+ a new tank as well as boiler
I have looked at thermal storage, heat bank etc etc etc
Even read about Atmos multi
So i was thinking of this idea
Two smaller combies in the airing cupboard. Each feeding a separate bathroom. One combi to heat downstairs rads and the other to heat upstairs rads. Effectively creating two zones to save on heating bills.
I figured the costs of labour won't be much more than putting a single one in and each combi will only be used half as much. No need to have downstairs rads on when you are sleeping at night or vice versa.
So what do you think?
I am more then ready to be the object of a bit of humor to all you experts out there. So go ahead and tell me how stupid this sounds but also give me the pros and cons as well.
Many thanks
Sean
PS: I am a General decorator by trade and not a plumber
But you can get a reasonable heat only boiler and an unvented for about £1400.
However it reads like another Drivel/Water Systems etc. attempt at posting to himself.
They will deliver about 22 litres/minute for ever,
I think you have misread the specification!
A 24 kW combi will only heat about 8 li/min to 44 C at this time of year!
You should go and play with a combi to see how they work. You would learn a lot more than just reading spec sheets!
I see Walter Systems has changed his name again.![]()
Gas meter is in the porch and the outlet from meter is the old iron pipe which I believe is just under 22mm if I am correct. As with all semis the pipe runs under hallway and goes up to airing cupboard under the stairs. Altogether the run is under 10 meters (5.5 meters from meter to staircase and up another 4 meters to airing C).
Upstairs there are 5 rads (4 for bedrooms and one for the shower room), so I was thinking a combi for this setup does not have to be very powerful. I figured that the sink in the shower room is never on at the same time as the shower.
So what size combi do I need?
Downstairs zone would feed kitchen tap, main bathroom shower and bath and 5 rads (rads being a bit bigger for lounge, hallway, dining room etc).
What size combi do I need for this zone?
As mentioned above, bath can be connected to both but we hardly ever use the bath. We are a family of 4 but both girls at the moment are at uni.
I was thinking that each combi with lower KW would cost around £850 and with the zoning system I might actually save money in the long run.
What would be the point of having the rads on downstairs at night when sleeping in the bedroom. These days with freezing temps many set their heating to come on in the middle of the night for bedrooms but no need to have them on downstairs and vice versa.
On the other hand as mentioned in another point, combis tend to break down quicker but would it compensate for the costs since each combi would be working half as much?
On a side note: The biggest problem I have had is to actually find a plumber who would “WANT TO” think about these things. As one plumber told me 3 weeks ago “Look mate, we go to a house and tell them they need a combi of this KW or a different system. They say OK and we get the job done. No one before has questioned what we do. You are asking too many questions. I have a combi in my own house and its working fine so if it is ok for me then you should be happy with this”.
Dr Drivel ( my favourite )
Water Systems
Joining the two DHW outlets is easy. Two check valves and a shock arrestor. A great selling point for the house.
