Hi All,
Have bought my first house an its a massive renovation project so doing alot of fast learning about many things.
We are finally starting to make things good again and I've started looking into tiles for bathroom and kitchen floors and walls. We have pretty much decided what we are going to get for those, so I started to look into what grout and adhesives I need to source. Reading on here I decided that it was worth doing the job properly and getting the BAL stuff.
I used the BAL powerspec online website to find out which products were best suioted to my tiles, but it ended up recommending ready mixed adhesives for the walls. I was just wondering if I listed out what tiles we were using and what products the website recommnded you could give your opinioons as to whether these are the best way to go.
Bathroom Floor
subfloor of 18mm wbp exterior ply screwed at 20cm centres to all joists, which are at about 30-40cm centres if memory serves.
Original Style victorian floor tiles, fully vitrified unglazed ceramic tiles, mostly 151 x 151 cm, with smaller tiles making up a border.
Products suggested by the website were Grey one part FastFlex adhesive and micro colour widejoint (I would get it in white) with admix GT1 added.
Bathroom walls
Will be tiled onto plasterboard (not sure if it needs to be MR) behind the sink, and onto aqua panel in the shower.
Should the aquapanel be skimmed or is it not worth it?
Tiles will be 300x200cm glazed ceramic.
products suggested were BAL white star and microflex grout.
Kitchen Floor
18mm ply subfloor, as in bathroom.
Tiles will be calibrated riven slate 10-12mm thick in sizes from 30x30 cm to 60x60cm.
website suggested single part fastflex grey and microcolour wide joint (in smoke) with admix gt1.
Kitchen walls
will be tiled onto skimmed plasterboard or existing concrete render and skim.
tiles are 10x20cm glazed ceramic.
suggested products are BAL bluestar with microflex grout. Would there be any problem with using the white star and microcolour wide joint (which seems to be suitable from 2mm anyway) as I would be getting that for the bathroom?
I am also hoping to fit 2 60x90 (12-14mm thick) slate tiles as a splashback for the hob, they will be fitted to existing concrete render and skim. Which adhesive and grout would be best for this? what is the best way to prepare the surface to hold such heavy tiles?
In all rooms I like the anti bac and water resistant properties of the microcolour range.
Oh yes, will be sealing the slate with Lithofin MN Stainstop and the bathroom tiles with Lithofin KF stainstop, as recommended by tile seller.
Thanks in advance for any help, I am well and truly confused - I think its a case of a little knowledge being a dangerous thing!
Bathroom Floor
Bathroom walls
Kitchen Floor
Kitchen walls
