Last night my living room ceiling lamp (which has a dimmer switch) popped and all the lights in the flat went out.
So far I have tried:
replacing the bulb (which had a burn on the plastic part)
replacing the fixture
refitting a fuse wire to the fuse next to the meter (although it didn't seem damaged)
None of these solved the problem.
Through googling it seems my next option is replacing the dimmer switch or dimmer fuse.
Does this make sense?
Any other recommendations?
Do I need to do something to the Henley box? Does this also have a fuse?
